Shopping Cart Item(s) 0 | Total: £0.00 Ex VAT
Show Prices:
Security Warehouse
0844 740 6581
Scantronic I-ON 16 c/w Wired Keypad
£78.98 Ex VAT
0 reward points
Model: ScanION16
Shipping Weight: 2.8kgs
Manufactured by: Scantronic
Online
Qty:
  • Easy to install, saving you time and money
  • Uses Scantronic Class leading radio system
    with improved signal strength
  • EN50131 Grade 2x for a professional installation solution
  • 16 Wireless zones, more than enough to cover
    a domestic or small commercial installation
  • Separate end station and keypad for additional security
  • Full Set and one part set
  • Accepts 2 wired and 2 wireless keypads
  • Four transistorised outputs to drive a wired sounder
    or basic home automation
  • Connects to the new Scantronic 760ES external
    radio sounder
  • 250 event log with date and time stamp
  • Option to plug on a speech dialler. Also transmits
    Contact ID and Fast Format for connection to
    monitoring services
Wired Keypad included
£30.00 Ex VAT
Ricochet wireless technology   Introducing the next generation of wireless security, Texecom's new RICOCHET mesh networking wireless...
Texecom Premier Compact PW-W
£60.85 Ex VAT
Description Hopefully, your staff will never need to find out why our personal attack transmitters are so highly regarded. But should they ever be...
Scantronic / 710r Dual Operation Personal Attack Transmitter
£3.23 Ex VAT
G2 Surface Contact with TACT tamper and Selectable Resistors Colour: White TACT Microswitch tamper Environmental Class II Operation Gap : 35mm...
Knight G2 Surface Contact with TACT tamper and Selectable Res
£4.12 Ex VAT
G3 Double Reed Surface Contact with Magnetic Interference Detection and Selectable Resistors White. This is compatible with all mainstream UK control...
Knight Grade 3, 4 Terminal Surface Contact
£17.03 Ex VAT
Grade 3 Model EN3-RSA Application Cabled / Terminals Cabled Suitable for Wood or Metal Wood or Metal Fixing Screws Operation Mode...
Elmdene EN3-RSA Grade 3 Roller Shutter Contact (Red Resistors)
£6.95 Ex VAT
  F10A Roller Shutter Single Reed 18" Dimensions: 150mm x 40mm x 15mm Operating Gap: 50mm IP67 Aluminium
SECWARE F10A Roller Shutter
Copyright © 2017 SecurityWarehouse.
