Shopping Cart Item(s) 0 | Total: £0.00
Security Warehouse
Pyronix Twin Alert Internal Sounder
£7.16
Model: PYROTWINA
Shipping Weight: 1kgs
7 Units in Stock
Manufactured by: Pyronix
Qty:
Main Features
Over 100dBa peak sound ouput
Speaker repeater with alarm override
Speaker volume override on alarm
Self contained siren generator
Compatible wth all bell trigger outputs
2 Year manufacturers warranty
£38.96
Description   The i-kp01 is designed to work with the i-on16 and i-on40 control units. The keypad allows the user to set and unset the system,...
Scantronic / i-kp01 Wired Keypad
£81.67
Description   The i-sd02 module is designed to fit on the i-on40 control unit. The i-sd02 allows the i-o40 to report alarm conditions over the...
Scantronic i-sd02 Plug-in SD/Comms Module
£23.00
Enersys 12v 17.2 A/h Battery
£34.93
High efficiency, cost effective range of Switch Mode power supplies for use in Access Control, CCTV and General Purpose applications. Modular...
Elmdene 2.0 Amp Output, plus battery charging. Box size A
£43.27
The EXP-W10 is a 10 zone wired expander designed for the i-onEX range of control units. This expander provides connections for: Either 10 Fully...
Cooper 10 zone wired expander for i-onEX Range
£6.74
Double Push Panic Button Latching Stainless Steel G3 Environmental Class 2 Microswitch Activation Dimensions : 91mm x 63.5mm x 29.mm Grade: 3...
Knight Double Push PA Stainless Steel Grade 3
Copyright © 2013 SecurityWarehouse.
