Shopping Cart Item(s) 0 | Total: £0.00 Ex VAT
Show Prices:
Security Warehouse
0844 740 6581
188381-010
£520.15 Ex VAT
0 reward points
Model: 188381-010
Shipping Weight: 4kgs
Manufactured by: IEC Trimec
Sold Out
188381-010 fail open solenoid 12v/24vdc
Product Overview
The TB38 range of drop bolts represent true engineering innovation, design excellence and the superior quality customers have come to expect and demand from Trimec. Designed for use on swing- through, double action doors, these drop bolts are ideal for applications where an electric strike is impractical. They include thermal protection so in the event of a solenoid overheat a thermal fuse will operate eliminating any fire risk.
High security bolt is deadlocked in the extended position. Bolt position monitored Door position monitor with integrated magnet into the strike plate (no need to install a seperate reed switch) Multiple orientation, drop bolts will work horizontally or vertically Power to lock/ Power to open with continuous rated solenoid Tamper proof, lock cannot be defeated by slipping a metal object between lock and the striker plate Intelligent electronics. These intelligent bolts will attempt to re close the bolt 8 times, allowing time for swing through doors to settle in the closed position
Copyright © 2017 SecurityWarehouse.
