There currently are 49 guests and
1 member online.
Quest PIR Deal
Fire Ancillaries
Relays, Repeaters etc
ACT Filters ACT 1414
ACT 1414
24v AC Filter for filtering AC Noise from the DC
£8.50
Add:
C-Tec C-TEC BF318
C-TEC BF318
BF318 REMOTE INDICATOR A high quality LED indicator specifically designed for use in fire alarm systems. Incorporating a red LED that is clearly...
£7.36
Add:
C-Tec C-TEC BF367
C-TEC BF367
BF367 KEYSWITCH OPERATED DEVICE ISOLATOR The BF367 allows a +24V d.c. output from a fire panel to be remotely isolated to prevent external...
£22.03
Add:
C-Tec C-TEC BF376
C-TEC BF376
BF376 24V 5A RELAY ON A PLATE The BF376 is a general purpose, double-pole, polarised 24V 5A relay designed for use in 24V fire alarm systems....
£15.89
Add:
C-Tec C-TEC FF502P
C-TEC FF502P
FF502P UNIVERSAL 4 ZONE SOUNDER CIRCUIT EXTENDER Supplied on a double gang plate and compatible with most fire alarm control panels, the FF502P...
£37.39
Add:
Cranford Controls CC R24-BOX
CC R24-BOX
RIU-R24 Auxiliary Relay The RIU range of auxiliary relays offer a rapid and cost effective solution to applications requiring the additional...
£27.70
Add:
Cranford Controls CC RIU-02 REMOTE INDICATOR
RIU Remote Indicator Unit The RIU range of remote indicator units are designed for fire detection systems requiring local indication of an individual...
£4.70
Add:
Dantech Dantech 8 Way Relay Card
8-way Relay Card. An 8-way version of the DA220. This unit has 8 independent DPCO Relays on one PCB. 12V DC operation. Metal Cased. The unit also has...
£83.29
Add:
Dantech Dantech 8 Way Relay Card Uncased
8-way Relay Card. An 8-way version of the DA220. This unit has 8 independent DPCO Relays on one PCB. 12V DC operation. The unit also has an inhibit...
£51.28
Add:
Dantech Dantech Quad Relay
Dantech Quad Relay
A quad version of the DA220 but with 4 comletely independent SPCO Relays on one PCB. 12V DC operation.  Metal cased. This unit is useful for...
£23.90
Add:
