Specifications: |
Operation mode | triplex |
Video standard | PAL/NTSC (automatic selection) |
Video inputs (amount) | 4 |
Video inputs | 4x 1Vp-p, (C)VBS, BNC (75ohms termination or loop-through) |
Main exits | CVBS, VGA |
Video outputs | 1Vp-p (C)VBS, (PAL: 50 Fps., NTSC: 60Fps.), 75ohms, BNC VGA |
Spot monitor | CVBS |
Audio inputs | no |
Alarm inputs | 4 inputs NO/NC, selectable |
Activity detection | Programmable 16x12 (192) masking grid, 4 levels of sensitiviy |
Alarm outputs | NO/NC contact |
Max. recording resolution | 720 x 288 (PAL) |
Compression standard | JPEG-2000, (Recording), H.264 (Network streaming) |
Image size | Basic: 14kB, Normal: 19kB, Enhanced: 24kB, Fine: 29kB, Super fine: 32kB (at 720x288 Px.) |
Max. recording rate | 200HB/Sek. |
Recording speed | 200 Fields/sec. at 360x144 Px., 100 Fields/sec. at 360x288 Px., 50 Fields/sec. at 720x288 Px. (PAL) |
Digital storage media | SATA HDD, Built-in CD-RW |
Max. harddisk capacity (internal) | 1000GB |
Harddisk capacity (internal) | 250GB |
Playback | Full, 4-channel split, PIP, Sequence, Digital Zoom, Frozen picture (in Live mode) |
Zoom function | 2x |
Intergrated writer | CD |
Secondary Storage | 2x USB 1.1 A&B interface, CD writer. Network data export: AVI & JPG |
Control units (external) | remote control, mouse |
Remote access | remote software |
Remote Software | Available (supplid with the unit) |
Search function | via timet, data and event (by Jog Shuttle) |
Menu languages | German, English, Spanish, French, Italian, Portuguese, Dutch, Danish, Estonian, Lithuanian |
Ethernet interface | 10Base-T/100-Base-TX, RJ-45 |
Interfaces external storage | USB |
Backup | USB Stick up to 2GB |
Serial interfaces | RS-232, RS-485, (PTZ control), RS-232C (PC) |
Security | Key lock, 64 user groups access rights programmable for each group (up to 256 user) |
Supply voltage | 100VAC~230VAC, 50/60Hz |
Power consumption | 80watts |
Temperature range (Operation) | +5
£33.32 Ex VAT Texecom AGB-0001 Exodus 12v Optical Smoke, Heat Multisensor Product Overview With a range of different detection and alarm criteria, the...
£2.40 Ex VAT SCART Adapter with phono connectors. SCART IN for displaying Composite video and audio on a SCART Compatible TV
£60.89 Ex VAT A power supply, with 4 x 1 Amp 12V DC (13.7V) fused outputs which will house and charge one VRLA battery up to 7Ah capacity. Typical uses are for...
£0.83 Ex VAT BNC crimp plug for RG59/62; URM70
£53.00 Ex VAT External Vandal Resistant Dome camera with built in IR led's. Lens:2.8-12mm zoom, IR-LED:36pcs IR distance: 35M Metal,IP66 1080P/2.0 Megapixel... Sold Out
£36.00 Ex VAT 100m Reel of 75 Ohm RG59/u coax combined with 2 cores for low voltage power supply. Also known as 'siamese' or 'shotgun' cable
