There currently are 47 guests online.
Risco Breakglass detector tester
Transmission
Wireless Transmission, IP, Telecoms etc
Genie CCTV Genie 4 Channel Passive Balun
Genie - 4-Channel Video Transceiver 4 x BNC to 1 x RJ45 and 1 x 8 Way Terminal Strip, One Video Signal Per RJ45 Pair (Pins 1&2, 3&6, 4&5,...
£16.10
Add:
Genie CCTV Genie Slimline UTP Passive Balun
Passive Video Balun BNC Male to Quick Release Terminal Block Low Profile Assembly - Ideal for DVR's Black ABS Finish Impedance matching 75Ω...
£5.89
Add:
Genie CCTV Genie Video Modem System VDS2500
Video Modem System, Transmits 2 x Composite Video Signal, 2 x Alarm Signal and 12V DC Power (Max. Output 1A) Over a Single Coaxial Cable. Kit...
£174.43
Add:
Genie CCTV Genie Video Modem System Video/Audio/Alarm/RS485/12v over 1 coax
Transmits 1 x Composite Video Signal, 1 x Alarm Signal, 1 x Audio Signal, 1 x RS485 Telemetry Signal and 12V DC Power (Max. Output 1.2A) Over a...
£237.68
Add:
NVT NVT Model NV-216A-PV Video Transceiver
The NVT Model NV-216A-PV Video Transceiver with Power is a passive (non-amplified) device that allows the transmission of real-time monochrome or...
£39.32
Add:
NVT NVT Model NV-704J-PVD Cable Integrator
Typically installed in the Wiring Closet or IDF room, the NV–704J–PVD is a passive "pass-through" wiring device that efficiently...
£92.88
Add:
NVT NVT NV-208A-M Video Transceiver Balun
The NVT Model NV-208A-M Video Transceiver is a passive (non-amplified) device that allows the transmission of real-time monochrome or color video...
£36.11
Add:
NVT NVT NV-214A-M Video Transceiver
The NVT Model NV-214A-M Video Transceiver is a passive (non-amplified) device that allows the transmission of real-time monochrome or color video...
£35.44
Add:
NVT NVT NV-218A-PVD Power Video & Data Transceiver
The NVT Model NV-218A-PVD Video Transceiver with Power and Data is a passive (non-amplified) device that allows the transmission of real-time...
£92.66
Add:
NVT NVT NV-413A 4 Channel Passive Tansciever
The NVT Model NV-413A Video Transceivers are passive (non-amplified) device that allows the transmission of real-time monochrome or color video over...
£325.44
Add:
