The Replacement of the popular BLP1 , the Blue Line Gen2 PIR Motion Detectors (ISC-BPR2) use two Fresnel lenses designed to produce sharply-focused images throughout the field of view providing superior
response to intruders. These lenses provide a high density (77 zone) 7‑layer pattern, and the selectable lookdown lens provides an additional three lookdown zones. Easy
installation and flexible mounting options provide state-ofthe-art detection.
First Step Processing (FSP)
First Step Processing (FSP) almost instantly responds to human targets without producing false alarms from other sources. FSP adjusts the detector's sensitivity based on
signal amplitude, polarity, slope, and timing. This eliminates the need for the installer to select the sensitivity level, thus improving ease of installation and reliability.
Test Features
- The externally-visible alarm LED can be disabled after installation.
- The sealed optical chamber prevents drafts and insects from affecting the detector.
- Temperature Compensation
- The detector adjusts its sensitivity to maintain its ability to identify human intruders at critical temperatures
Technical Specifications
Electrical Current (standby/alarm): 10 mA at 12 VDC
Voltage (operating): 9 VDC to 15 VDC
Environmental
Environment Complies with EN50130-5 Class II
Relative Humidity: 0 to 95%, non-condensing
For UL Listed product installations,
0 to 85%, non-condensing
Temperature (operating): -30°C to +55°C (-20°F to +130°F)
For UL Listed product installations, 0°C to
+49°C (+32°F to +120°F)
Mechanical
Color: white
Dimensions: 105 mm x 61 mm x 44 mm (4.2 in. x 2.4 in. x 1.7 in.)
Material: High-impact ABS plastic
Radio Frequency Interference (RFI)
Immunity
No alarm or setup on critical frequencies in the range from 150 kHz to 2 GHz at field strengths less than 30 V/m.
Outputs
Relay: Solid state, supervised, Form A normally-closed (NC) contacts rated for ≤100 mA, 25 VDC, 2.5 W, <20 Ω closed
Tamper: Normally-closed (NC) contacts (with cover on) rated for ≤100 mA, 25 VDC, 2.5 W Connect tamper circuit to 24-hour protection circuit.
This product was added to our catalog on Tuesday 29 November, 2011.
