Shopping Cart Item(s) 0 | Total: £0.00 Ex VAT
Show Prices:
Security Warehouse
0844 740 6581
ADE OPTIMA G3 CONTROL PANEL
£34.40 Ex VAT
0 reward points
Model: 8ep395
Shipping Weight: 4kgs
Manufactured by: Honeywell
Sold Out
Optima G3 now obselete replaced by Gen4 Range
On board keypad & display: Yes
Simple Set Interface: Yes
RKP Indication: Yes (not supplied)
8 Zones: +ve loop, fully programmable
Tamper: -ve loop global
PA: -ve loop
Bell Output: 12V latching, timed 1 to 99 minutes
Strobe Output: 12V
Extension Speaker: Max two 16 Ohm
Entry/Exit Timers: Programmable 10 to 990 seconds
Zone Input Delay: 300 or 800ms selectable
Set +ve Output: Source 10mA, sink 40mA, programmable polarity
CPU Current consumption (standby): 55mA
RKP Current consumption (standby): 25mA
Low voltage output: 13V +/- 5%
Rechargeable battery: Up to 7Ahr
Communicator outputs: Yes
Communicator output types: Intruder, PA, Confirmed, Fire, Abort, Set
Communicator input: Line fail
PCB Fuses: 1 x 1.6A, 3 x 1.0A
Mains input fuse: 125mA anti-surge
Total current output: 1 Amp when supported by fully charged battery
Mains supply voltage: 230V +/- 10%
RKP wiring: 6 core Max distance 100m
Dimensions CPU (HxWxD): 230 x 290 x 80mm
Compatible Products:
8EP219: Accenta LED RKP
8EP332: Accenta LCD RKP
8EP336: Accenta Speech Dialler
8EP276: Informa Speech Dialler
£2.16 Ex VAT
Panic Button Single Push Panic Button Dimensions : 91mm x 63.5mm x 29.mm Environmental Class: 2 Latching White ABS Tamper - Leaf
Knights Plastic Single Push Panic Attack Button
£3.62 Ex VAT
Dummy backplate for Odyssey 4 Series Note picture of Ody 4 LIVE shown Alternative Honeywell AG6 Decoy Complete Unit £7.00
Texecom Premier Elite Odyssey 4 Dummy Backplate Blue
£16.80 Ex VAT
Discover a new level of excellence with the Odyssey 4 from Texecom. Stunning low profile aesthetics conceal advanced microprocessor technology, IP65...
Texecom Premier Odyssey 4E Live Backplate BLUE
£12.23 Ex VAT
The ShockTec with Magnetic Contact ensure double protection on opening windows and doors. The detector can be mounted vertically or horizontally,...
Rokonet ShockTec with Magnet White
£14.18 Ex VAT
Obsolete Replaced with 8EP416 8EP219
ADE Accenta / Optima LED Keypad
£5.99 Ex VAT
Cover for Odyssey 4 Series of Bellboxes (White)
Texecom Premier Elite Odyssey 4 Cover White
Copyright © 2017 SecurityWarehouse.
