Basic Kit comprising of 1 x Optima Gen4 Compact and 2 x Activ8 18m Quad Pet PIR's
8 Zones
3 part set programs
operation
Personal attack facility
5 Digi-Outputs
New LCD Keypad
The LCD remote keypad operates with the Accenta and Optima Gen4 intruder systems. Up to four LED or LCD keypads can be connected to the system. The large 2x16 characters with backlight display provide a full status indication and the keypad plays entry and exit tones.
Fire Zone
250-event log
Duress Code
Chime
Can be used to select a low security chime alarm for various areas of your house, even when the main alarm is turned off. When a door is opened or a detector triggered in an area set to chime, the control panel will deliver a low-volume ‘bing-bong’ sound to alert you. This is ideal for areas that require low level monitoring.
Built-in tamper control
To protect all wiring and detectors in the system from unauthorised access including the control panel and remote keypad covers.
Zone names selectable from the library
A new option accessible from the LCD remote keypad allows the installer to assign descriptors from a 22-name library to each of the eight zones.
This product was added to our catalog on Wednesday 21 April, 2010.
