Proximity Readers
Prox readers are the non-contact type readers and have replaced mag-swipe as the access system of choice in most systems
Proximity ReadersProximity Readers Prox readers are the non-contact type readers and have replaced mag-swipe as the access system of choice in most systems £2.98
Videx Proximity card for Videx Access Control Systems. 2X - VProx Card £4.31
A grey round proximity tag for use on any of the Vprox systems. (35mm diameter) £4.51
A grey round proximity tag for use on any of the Vprox systems. (35mm diameter) £4.99
ACTWin Smart is a simple, easy to use PC application that allows configuration and monitoring of up to 8 ACTsmart2 devices and is used in... £25.84
Product Overview The ACTsmart2 Lock is designed to improve the security of ACTsmart2 installations. Features ACTsmart2 Lock allows the lock control... £53.50
Proximity Reader - Blue Part of the Portal Plus. A surface mount aluminium IP65 rated Wiegand proximity reader in blue finish. Includes a sounder and... £53.50
Proximity Reader - Dark Grey Part of the Portal Plus. A surface mount aluminium IP65 rated Wiegand proximity reader in blue finish. Includes a... £53.50
Proximity Reader - Green Part of the Portal Plus. A surface mount aluminium IP65 rated Wiegand proximity reader in blue finish. Includes a sounder... £53.50
Proximity Reader - Red Part of the Portal Plus. A surface mount aluminium IP65 rated Wiegand proximity reader in blue finish. Includes a sounder and... |
