There currently are 48 guests and
1 member online.
Quest PIR Deal
24v 32 Tone Sounder EN54 P3 Appproved Deep Base WHITE
£14.16
This sounder has been fully approved to EN 54-Part 3 by the LPCB and VdS on tones 1, 8, 11, 25 and 27.
All the standard features are retained including the facility to select from three volume settings via the DIL switch. This allows individual sounders to be retro-converted to high output devices where additional sound output is required.
Tones are selected via the DIL switch on the PCB. By using 3-wires, a second stage alarm may be switched so that the second tone will over-ride the selected tone.
Standard with all VTG products is a universal locking system. Utilising an industry standard grub screw, each VTG product may be locked in place, making VTG fully compliant with the latest requirements of British and European standards.
Quick fit mounting is achieved by the bayonet fixing arrangement on each base and is standard on both base variants. The deep mounting base features a throw-away cover plate for surface mount wiring. This is kept in place when wiring directly through into the rear of the product.
Part No. VTG-32-SB VTG-32-DB
Sound Level: Low Med High Low Med High
Sound Output @ 1 metre Tone 1 86dBa 101dBa 106dBa 86dBa 101dBa 106dBa
Current Consumption @ 24Vdc ≤ 9mA ≤ 18mA ≤ 36mA ≤ 9mA ≤ 18mA ≤ 36mA
Voltage Range 21.6 - 28Vdc
Number of Tones 32
Operation Frequency 440Hz - 2900Hz
IP Rating IP21C IP33C
Temperature Range -20°C to +70°C
Weight (per unit packed) 220g 250g
  • Model: VTG-32E-DB-W
  • Shipping Weight: 0.25kg
  • 2 Units in Stock
  • Manufactured by: Cranford Controls
This product was added to our catalog on Wednesday 22 September, 2010.
