There currently are 43 guests and
1 member online.
ESP_GuardCam
110v / 230v 32 TOne 107dB Sounder White
£32.88
The Viper spatial 32-Tone 110-230Vac sounder is designed to give a high output for applications requiring a mains operated sounder and where a non standard tone may be required. It includes a wide range of sound patterns and frequencies compatible with International requirements.
Each device is synchronised via its high frequency oscillator circuit, and gives sound outputs with frequencies of between 440 to 2850Hz. (dependent upon tone selected).
Tones are selected via the DIL switch fitted to the PCB. By using three wires, a second stage alarm may be switched so that the continuous tone will override the tone selected.
The sounder case material is ABS and is supplied as standard in red. A white version is also available.Each sounder is supplied complete with its own mounting base, which contains marker points for drilling two M20 gland entries.
The installation of the VPR-MT32-230 sounder is not recommended in chilled areas
These units do not require an earth connection as each device has its own transformer and de-coupling between mains frequencies.
Part No. VPR-MT32-230
Output @ 1 metre 107dBa
Current @ 24Vdc c. 12mA
Voltage Range 230Vac /110Vac +/- 10%
Operating Frequency 440Hz - 2850Hz
Number of Tones 32
Volume Control -30dBa
IP Rating IP65
Temperature Range -20°C to +70°C
Weight (per unit packed) 295g
  • Model: VPR-MT32-230-W
  • Shipping Weight: 0.3kg
  • 16 Units in Stock
  • Manufactured by: Cranford Controls
This product was added to our catalog on Wednesday 22 September, 2010.
